when do use????gas ..n00b
Old Feb 1, 2003 | 05:29 AM
wm5holla's Avatar
Default when do use????gas ..n00b
when must you use super gas, and race gas
Old Feb 1, 2003 | 10:49 AM
Kamin's Avatar
Default Re: when do use????gas ..n00b (wm5holla)
i was gonna post this in your other thread
why do you think you need race gas? its only need for very high compression motors or motors that run HIGH boost.
i just get 92/3 or whatever is at the pump.
running racegas if you dont have to is stupid and will probably hurt performance. more octane dosent mean more power.
Old Feb 1, 2003 | 12:31 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: when do use????gas ..n00b (Kamin)
, use 93 octane on your lsvtec with 12.3 -1 compression, its fine
Old Feb 1, 2003 | 08:56 PM
wm5holla's Avatar
Default Re: when do use????gas ..n00b (SIXTYdashONE)
but if my CR is over 13? then what?
Old Feb 1, 2003 | 09:11 PM
ekb18c's Avatar
your compression wont be over 13:1 unless you are using some crazy domed pistons. If you plan to use CTR pistons on your ls/vtec then you will be fine with 93 or 94 octane.
Old Feb 7, 2003 | 06:29 AM
wm5holla's Avatar
Default Re: when do use????gas ..n00b (ekb18c)
when MUST you use race gas?
Old Feb 7, 2003 | 06:31 AM
wm5holla's Avatar
when do u get race gas from if thre track isCLOSED
Old Feb 7, 2003 | 07:11 AM
1BlackHatch's Avatar
If your compression is too high or you are using a lot of boost (increasing effective compression) then you must use higher octane fuel and more of it to prevent detonation.
Old Feb 7, 2003 | 07:13 AM
wm5holla's Avatar
Default Re: when do use????gas ..n00b (1BlackHatch)
how high?
Old Feb 7, 2003 | 07:21 AM
Depends on the motor. People say that hondas can run higher compression than other motors due to the superior cooling ability of aluminum heads and their combustion chamber geometry. Also, injecting more fuel cools the mixture and prevents detonation. Most people feel that a wee bit over 11:1 is ok on high octane pump gas. The problem is when you get a little too high, you need to retard timing to prevent detonation. If you retard timing, you lose the HP you gained from uping compression. Most people seem to think that around 12:1 and race gas is in order.
Please note that I am being conservative when I give those ratios. I am also very conservative in what I chose to believe.
Old Feb 24, 2003 | 01:24 PM
dropd4door's Avatar
omg you are a retard
Old Feb 24, 2003 | 02:18 PM
integra6650's Avatar
Default Re: when do use????gas ..n00b (jdm_crx_vtec)
whos a tard
Old Feb 25, 2003 | 07:01 AM
Cuong-nutz's Avatar
if he is so, state the facts.....educate if you hate...
WarpedSportzKid
Feb 8, 2007 01:11 PM
enigma94
29
Apr 5, 2006 02:08 PM
Justin Olson
Jan 13, 2006 04:28 AM
blusmke
Sep 26, 2004 03:02 PM
ingrate
Jul 16, 2001 06:44 PM
