crvtec rev limit before bottom end build up
what was your rev limit set at, on your crvtec before you decided to build the bottomend? what things did you do, to the engine in order to set the rev limit(i.e. springs and retainers, z10 girdle, better fuel pump, etc..)? any noticable side effects from the higher rev limit? TIA!
Re: crvtec rev limit before bottom end build up (smokey2.0)
I revved my completely stock bottomend jdm b20b to a rev limit of 8290 every day, all day.
My engine stopped making power @ 7400 & the only reason I went above that is to keep my momentum up in curves. @ the dragstrip I usually shifted @ 7700-7800 rpms as those were the best times I got w/ my car.
As far as building it up... build a streetable b20/vtec that makes power past 8200 & then you should worry about adding those parts you listed.
Pete
Pete
Re: crvtec rev limit before bottom end build up (pest)
Pete
Pete
95 civic CX hb full interior 2340 lbs w/ me in it
stock bottomend b20b JDM style
stock 1st gen b16a head w/ Skunk2 cam gears
ITR manifold w/ GSR T-body
Iceman shortie intake... for a sohc
DC 4-2-1, Catco Cat, & Thermal catback
P28 chipped
VAFC tuned
GSR tranny w/ Quaife
A/C still attached
205/60/13 Yoko AVS Intermediates @ 21 psi on the stock steelies
GC 400f & 450r w/ KYB AGX set @ 2F & 4R
60' 2.136 Launching @ idle
1/8 8.9
1/4 13.8 @ 100 mph
I tried every Rpm from 7200 to rev limit of 8290... I have went to the track several times w/ this setup & have a mtn of slips from trying different things.
Any other questions??
Pete
[Modified by pest, 3:51 AM 2/2/2003]
P28 chipped
VAFC tuned
A/C still attached
1/8 8.9
1/4 13.8 @ 100 mph
Pete
good piece of driving.
mine is in a 88 crx, full interior 2310lbs with in it!
no header, or cat back, all stock pipeing.
single cam short aem intake.
skunk2 intake manifold, fidanza flywheel, jdm y1 tranny.
yokohama intermidiates 15", worn probably 60-50% tread left!
chipped pr3:
2.3 60' mi best
14.46 1/4 no traction in first and second!
96-97 mph trap speeds!
my best 1/8 is 9.386 @ 76.99 mph 1/4 @ 14.47 @ 96.84mph!
chipped pr3:
2.3 60' mi best
Re: crvtec rev limit before bottom end build up (speedracer2kjory)
i have a sock b20 in my hatch and i run low 13s
Pete
best of 15.02 @ 93.8mph on almost stock setup (only mod = tuned cam gears)
i have tried launching from idle, its OK, but still cant get to 2.2's
maybe it is my crappy street tyres...
t..
PS i rev to about 7900 which is where the stock b16a cams start to feel restricted by my 2in exhaust...
Re: crvtec rev limit before bottom end build up (tinkerbell)
on a B20VTEC would you say the Quaife helps alot? i am having trouble cracking 2.3 60's with my set up, on street tyres at 18psi...
Pete
[QUOTE]
i missed that one, it sure makes a difference. i can't wait to get mine, but i still haven't decided what tranny to stick with. my 2.3 60' was with street tires, at about 28 to 30 psi! i wanna see how the car hooks up at the track, with the falken azenis i have up front! hey pest do you daily drive your car? how do you like the quaife lsd in a daily driver?
*pest* how long have you had the B20/vtec in your car? and have you had any problems w/ it?
[Modified by Typesi2nv, 2:08 AM 2/17/2003]
SpoolnByYou
11-20-2006 08:55 AM
quicksol95
14
04-02-2004 10:19 AM
