Will ODD2 Distributor fit on JDM b16a head with 94 civic dx wire harness
Will OBD2 Distributor fit on JDM b16a head with 94 civic dx wire harness?
Will any gray plug obd1 or obd2 distributor fit an jdm b16a head with a 94 civic dx wire harness?
[Modified by gemini182001, 10:35 AM 2/2/2003]
Re: Will OBD2 Distributor fit on JDM b16a head with 94 civic dx wire harness? (gemini182001)
Yes..... It'll bolt onto the head no problem, and will work on your 94 Civic (FYI, the OBD-1 and OBD-2 DOHC VTEC distributors are the exact same). The only thing that you'll need to do is repin the plugs to OBD-1 plugs... use your (or find another) stock Civic distributor and take those plugs off and use them onto the OBD-2 distributor and match the wires accordingly by color and you're all set.
Re: Will OBD2 Distributor fit on JDM b16a head with 94 civic dx wire harness? (Newman)
Re: Will OBD2 Distributor fit on JDM b16a head with 94 civic dx wire harness? (civicvteckid)
what about using an OBD-0 dist.? Would that work with an OBD-1 ECU?
97_coupe
03-04-2008 06:19 AM
everythingwentblack
05-07-2006 05:16 AM
SuicideSlide
14
05-16-2005 12:10 PM
rice4life
03-07-2004 08:02 PM
