Need all your info on EG H22a swap!!
ok, starting my swap tomorrow morning at 9am and not going to stop til it is done. it is me and 2 of my friends working on it. If you guys could send me what ever docs you have that would be sweet!
I will be giving updates as I make progress. any tips would be very appreciated! If someone wants to be a REAL trooper, maybe I could get an IM name or phone# if I get stuck in a jam. I believe I have everything I need from axles to shifter. My e-mail address is amorales@buffalo.edu if you want to send your docs away
Thanks!!
btw, it is a JDM H22a going into a 92 si hatch.
Thanks!!
Re: Need all your info on EG H22a swap!! (LoudAccord)
remove the old motor. take the Si harness and modify it to 'lude specs, meaning lenghten the alternator cable/wires (using the prelude cover), add in the injectors plugs with the resistor box, lenghten the IAT, TPS, MAP, 02 sensor wires, change the back up light plug. add in knock sensor, EGR.
poison, newman and few others have done the swaps PM them for more info and short cuts
