need SERIOUS HELP!!!! with swap
Im only 22 and have been teaching my self about hondas and acuras through just taking stuff apart, having a helms manual and trial and error .
In my latest attempt I tried to take my auto matic 94 ls and swap a 98 GSR in including manual trans. The PROBLEM is that the car wont turn on. the interior harness is obd 1 the engine harness is obd 2. the starter and battery have been checked. the neutral safety switch is in neutral. I am at brick wall now. when i put the ls auto ecu in you here the starter make a ticking noise and the dash lights flicker. the throttle cable also started smoking once . the harness tower on the passenger side has one clip from the car that does line up with harness on the engine.
should i use my automatic 94 ls harness , distributor and injectors and just run wires for the knock sensor and vtec (also the ecu is a p28 chipped that i have to install)
thanks for reading the long post and all info is greatly valued thanks
Re: need SERIOUS HELP!!!! with swap (dtyst)
ok ok ok... on a serious note. 3 things, will the motor run on the old LS ECU? If not, are you sure the GSR starter is good? It may need new contacts or try your old starter. The thing I would check first is that you've got all the ground straps properly fastened to the car/frame.
Just curious how the safety switch is in neutral if the auto linkage is completey torn out in exchange of a 5 speed linkage and ecu? if you ned help let me know and ill tell you but I want to see where your at first.
Re: need SERIOUS HELP!!!! with swap (proclassracer)
the manual shift linkage is in the car, but normally the neutral switch would be connected to a plug that is at the top of the clutch pedal . those wires are the same ones that attach to the shift lever on the automatic shifter.once i took the shifter out i disassembled it so that i could manually push the switch into either the neutral or park position to close the circuit....allowing the car to attempt to turn on.
[Modified by dtyst, 1:23 AM 3/18/2003]
Re: need SERIOUS HELP!!!! with swap (Slurp56)
where are the grounds exactly ? cause i only connected 2 definately that i am aware of. the 1 to the tranny and the other on the valve cover , i was told there are 4 ..thanks
On the auto shift assembly plug there are two thick gauge wires, bottom row in the middle. I believe the colors are blk/red and blk/wht. Connect these together and see what happens. This will bypass the switch and should allow the car to crank. Im assuming the car doesnt crank or am I jumping the gun?
will that make a difference even i have the piece from the auto shifter in ? you can hear the starter making an attempt to spin . do u think its the engine harness? should i use my initial harness from the ls and just take the distibutor and injectors off the ls and put them on the gsr?
Location: First in Flight, Type Rs of East Coast, NC, FL
kiss, keep it simple stupid....check battery voltage, ground connections, starter connections, etc.
If the cars attempting to start it wont be wiring. check battery voltage and things along those lines.good luck
tlarimer
08-30-2009 11:51 PM
