Safe to heat Axel hub nut?
Re: Safe to heat Axel hub nut? (Holden)
youll probably need to put some impact to it, before trying to remove it. But i wouldnt recommend heating it.
[Modified by iwhichisme, 1:09 AM 3/12/2003]
Re: Safe to heat Axel hub nut? (egciviccx)
I was thinking about how hot my wheels get when racing and I figure the propane torch won't get them that hot.
Off to try it. Liquid Wrench has been at work for an hour.
[QUOTE]I was thinking about how hot my wheels get when racing and I figure the propane torch won't get them that hot.
QUOTE]
uhh, before you go im hoping you take the wheel off first before breaking the axel nut loose...
QUOTE]
Don't worry. I didn't mean taking the torch to the wheels.
It didn't work though. Another Liquid Wrench bath and I'll try again tomorrow.
Re: Safe to heat Axel hub nut? (97hb)
Impact guns are nice but not everyone has access to air tools. Anyway, yes you can heat the axle nut to help remove it. The use of a nice 3-4 foot metal pipe on a 1/2" breaker bar usually does the trick.
if you still have the tires on the car and you can access the hub with the rim on. that is the easiest way. and usually will get it off with some force
Re: Safe to heat Axel hub nut? (baonest)
heating it will work, that is usually my last resort but it is a tried and tested method. Best is a 3/4" impact gun.
4doorH22
11-08-2002 08:07 PM
