How to wire up my swap????
In need of expert advise.
I have a 99 jdm itr complete swap. My ride is a 1995 ex. I'm going to reprogram my P28 so I''m not worried about the KS wire. My problem is wiring the motor up. Which harnesses can I use and which is less work. I been told that I can use a 96+ gsr harness which will plug and play with all the clip on the motor, but will it match up with the interior harness on the tower is my question. If I use a 95 del sol harness is the distributor, injectors, and alternator the only things that I have to splice and rewire. The motor will come with its RHD engine wire harness so I can reuse the clips on them. I would love to use a 96+gsr harness so that everything will plug and play especially since I'm using my p28 I think I wouldnt have to rewire anything.
1. 95 del sol DOHC vtec harness
2. 95 ex harness
3. 96+ gsr harness
2. 95 ex harness
3. 96+ gsr harness
Re: How to wire up my swap???? (turkdog)
Not Bashing. Cant believe Im about to say this.
But do a search they are really helpful. You may not learn everything right away but you will learn something.
Well, you have several options. Since the ECU you are using and the Car is OBD1 (shock tower harness), I would personally conver the jdm ITR motor to OBD1 and use the EX harness.
You will need to convert the distributor over to OBD1, you can simply use your EX plugs on the ITR dist and wire it up. You will just need to cut off the OBD2 ITR dist plug and use the EX one instead.
HTH
HTH
Re: How to wire up my swap???? (poison)
But like posion said, you can use your stock EX harness as well since you will have the plugs to salvage from the JDM harness. Either way will work, but using the OBDII GSR is a lot less work.
MWLW20
08-10-2009 02:01 PM
u2civic1
02-05-2003 09:44 PM
