B20/VTEC builders... Will this be the way to go??
Im going to do my first B20/VTEC and Im pretty mechanically skilled ... Ive taken apart engines and rebuilt them.
Anyone know of good sites to visit for a thorough reading or a member that is willing to help through the process??
Also wat do you guys think of buying a first gen B16A and breaking it down than buying a B20 bare longblock and putting it together....
Thanks.
anymore things I should consider??
Thanks.
Re: B20/VTEC builders... Will this be the way to go?? (EGB18hatch)
http://www.c-speedracing.com
Go to the how to"s
Go to the how to"s
Ask away. I will help where I can or I will send you in the right direction.
What are your plans for it?
EDIT:
Why not just look for a VTEC head? I would recommed putting pistons and rods in it though, not just bolting the thing together.
[Modified by Jeff C, 10:31 AM 3/17/2003]
EDIT:
Re: B20/VTEC builders... Will this be the way to go?? (Jeff C)
Alright found a deal on a complete first gen B16A head.... its all the same right?
Now I gotta find the block and I'll take your advice to buy rods and pistons.....
I think wiring is where Im gonna need the most help....
What harness to use and what ecu.... Since I have a first gen head, and B20 block... my car is an OBD2 97 DX.
Thanks I appreciate it.
How much you looking to spend? Fi or NA?
I am using a 1g b16 head, and I would suggest different cams.
The ecu norm seems to be the chipped p28, which is what I have too.
Engine harness? I am using my stock 89 CRX Si engine harness. I did have to add a couple of things, but nothing major.
