Need Info on Ls/Vtec Setup?
Old Mar 10, 2003 | 08:34 AM
Tru_Hybrid's Avatar
Default Need Info on Ls/Vtec Setup?
I need help with determining my hp/tq on my hatchback. I know I need to get on a dyno, but the closest dyno around me is about 4 to 5 hours away. So I planning to do that in the summer time. In the meanwhile, I was wondering what hp/tq should I be around. Thanks in advance.
Here is my setup: (Some of the things might not be performance related)
97 integra type-r items:
1.5:1 LSD tranny
strut bar
front end incl radiator support
intake manifold
stock injectors
96 Integra LS bottom end / head gasket/ stock pistons / underdrive
pulley
96 GSR a/c bracket
B16A1 Race Head ported ,polished, and milled.
civic type-r Cams
B16a cam gears
double springs in the head
96 integra LS distributer / cap/ and rotor
Greddy header
MSD coil and amp ignition
96 GSR NGK platinum spark plugs
magnacor 10mm wires
JG throttle body
R-Tec intake
ACT street clutch
96 GSR axles
17" Bronze TE37 Volks
STR fuel regulator
V-afc
[Modified by TruHybrid_Honda_Integra, 5:36 PM 3/10/2003]
Old Mar 10, 2003 | 08:45 AM
AudioXtremes's Avatar
Default Re: Need Info on Ls/Vtec Setup? (TruHybrid_Honda_Integra)
1,000,000 hp 960,000ft lbs.
Dude who knows. every setup is different. Go to the dyno, you can do some tuning there to.
Old Mar 10, 2003 | 10:00 AM
Tru_Hybrid's Avatar
Yeah, I know I need to go to a dyno. I won't be able to go until the summer, that's why I just wanted to get an estimate from people who might know from previous experiences.
Old Mar 10, 2003 | 10:02 AM
ill phil's Avatar
Then search, about a million people ask about Hp/Tq from set-ups every month. See if any are close to your set-up.
SydneyLS
Nov 20, 2008 12:27 AM
414teg95ls
Jan 14, 2008 01:02 PM
Tru_Hybrid
Dec 28, 2003 09:12 PM
Tru_Hybrid
Nov 30, 2003 10:09 AM
