need help crv vtec swap but i am lost
hey,
can some one help me!!!!!! what and where can i find mounts to put this engine in as well as what axles and shiftlinkage do i use i have a 95 gsr.i have my catch can already to go i just can't get in,up and running (get your mind out the gutter)
any experts please holla back.i would like to be driving again.this acr is also my every day driver as well. [
Re: need help crv vtec swap but i am lost (kenhaile8332)
OK if you got a 95 gsr and you want to put a b20 into it,you dont need anything.Use your head and slap it on the block and everything else you reuse like your mounts tranny axels ect....If you need any more help use the search but cause it does help alot.Good luck
Re: need help crv vtec swap but i am lost (J2turbo21)
true, all you're really doing is changing the bottom end. the only thing that you'll need to do, is to prep your gsr head for the external oil line. you'll need one of these! http://www.groupbuycenter.com/buy.aspx?id=9181 good luck!
