I have a 94 hatch h22 wiring problems
i have a 94 civic hatch with a 2000 h22, i am having problems with the wiring i am using a obd 1 gsr wiring arness and a gsr computer i lengthened all the wires and made it fit but when i go to start it there is no spark, HELP ME PLEASE
[Modified by kevgnuboy, 2:11 PM 3/10/2003]
Re: I have a 94 hatch h22 wiring problems (kevgnuboy)
Where the hell is endicott at??
And first a few questions? What ECU are you using? Did you convert to on ODB I distributor?
Re: I have a 94 hatch h22 wiring problems (Jason kiDD)
should have left the harness that was on it...all it needed was 92-96 dist.
and did you get the P13 ecu???
Re: I have a 94 hatch h22 wiring problems (VTEC93hatch)
[Modified by brryder, 6:21 PM 3/10/2003]
Re: I have a 94 hatch h22 wiring problems (UtahRockabilly)
Well first off you should have used your civic harness. Actually should have gotten a ex harness (which would have been ideal) From what i know that GSr harness wont work with your civic dash harness. Ill look into it more, but im pretty positive you need to grab yourself a 92-95 EX civic harness and rewire from there. Should start right up after that.
OBD1 plugs will be the same and should clip right into the firewall harness.
You will need to conver the distributor connectors to OBD1 by using your stock civic harness plug from the dist. Cut off the obd2 connectors on the prelude dist and match the wire/pin-outs on the obd1 connector.
SpoonFed
05-22-2003 06:45 PM
riceboyEFsi
03-23-2003 04:32 PM
