exhaust gasket between 'a' and 'b' pipe??
B16a, should there be a gasket between the 'a' and 'b' pipe. The exhaust manifold (4-2) and the downpipe (2-1) .... I have a leak there, didnt have one for the first month after doing my swap.....now all of the sudden i do (too much vtec?). Should there be a gasket there?? What car should i get one for? Or are all vtec manifolds close enough? ie. del sol vtec, civic si, gsr??? what will work for me...?
Thanks
Thanks
Re: exhaust gasket between 'a' and 'b' pipe?? (b19coupe)
Hmm, thought it was one piece.... So did the guy at Napa when i went in there for a GSR gasket, he said it must have been inventoried wrong...
ok the integra gaskets didnt work, now i have stripped studs holding the pipe on loose, that wont come either in or out. Anyhow, does anybody KNOW what car to get these from??? It's impossible to get Del Sol **** around here.....
Re: exhaust gasket between 'a' and 'b' pipe?? (sick hatchem)
find out your piping size and apply those size gaskets. i am using random **** to hold my bolts in. just make sure they fit snuggly. no leaks here.
Re: exhaust gasket between 'a' and 'b' pipe?? (all stock)
what about the 99-00 civic si? thats a b16a3....i dont know if the exhausts are the same but its worth a shot to find out. post your findings
Re: exhaust gasket between 'a' and 'b' pipe?? (keebler65)
Still havent found anything..... car sounds like ***. Tried the GSR gaskets, too big, and i was told from somebody that tried that the del sol gaskets are too big too.
STREETFIGHTER50
06-06-2011 05:52 PM
mikeunreal
11-21-2005 06:38 AM
