Fuel Pump?
Old Mar 13, 2003 | 09:18 AM
AB16A2T's Avatar
Default Fuel Pump?
Ok I have a 99 B16A2, in a originally SOHC car. Will the old fuel pump be able to provide enough fuel for the DOHC motor? Or should I switch it out the B16A2 fuel pump?
1999 Civic EX if it makes a difference.
[Modified by AresB16A2Turbo, 10:18 AM 3/13/2003]
Old Mar 13, 2003 | 09:41 AM
hybrider's Avatar
Default Re: Fuel Pump? (AresB16A2Turbo)
the GS-R/ITR pumps flow higher
the rest are all the same as far as flow rate...you should be fine, i noticed a slight bump in the high end with a GS-R pump...nonetheless, you should be able to find em at a local junkyard for under $50
Old Mar 13, 2003 | 09:59 AM
AB16A2T's Avatar
Default Re: Fuel Pump? (hybrider93)
Ok well I was just curious, because a SI fuel pump came with my swap, so I just wanted to check.
Old Mar 13, 2003 | 02:15 PM
ITRacer121's Avatar
I was wondering the same thing
IM doing a B18B into a CX
rpared01
Jul 12, 2007 09:21 AM
erubio14
Nov 25, 2005 10:28 AM
eg6style
Sep 7, 2004 11:38 PM
2000CX
14
May 13, 2003 01:49 PM
Patron
Apr 17, 2003 03:28 PM
