which is better ls ecu in b20 or dx
does anyone feel a difference , cause i'm using a dx, tried my friends ls ecu felt faster but did not use it long enough to tell, dont want to buy ls ecu if it does not produce power...???
Re: which is better ls ecu in b20 or dx (brryder)
asking for a friend. he has a b20 in his eg and is currently using a dx ecu. He was wondering if it would make a difference if he used a ls ecu.
Re: which is better ls ecu in b20 or dx (locass316)
might want to check here hybrid did a write up like 2yrs ago on the comparsion http://hybrid2.honda-perf.org/tech/b20/b20dyno.html
New User
92-95 ls ecu is the optimal choice
but the dx makes slightly more power above 5700 so its good if your gonna tune
Re: which is better ls ecu in b20 or dx (usdmRob)
DX only makes power because it tends to run very lean.
you can chip your P06 to PR4 (OBDI LS specs) .. or run another chip which I offer for the P06
moike
03-14-2005 09:18 AM
boywonda
09-21-2003 09:56 AM
