OBD2b to OBD1 problem
Old Mar 13, 2003 | 09:22 AM
rsaeini's Avatar
Default OBD2b to OBD1 problem
What exactly do I need to do to mate a OBD2b (99 Si) ECU with my current OBD1 (95 Civic Si) system???
Are there any conversion kits for this? Who makes them?
Old Mar 13, 2003 | 09:27 AM
2trix's Avatar
Default Re: OBD2b to OBD1 problem (rsaeini)
kenji makes an awsome conversion for obd cars! he does 2 to 1, 1 to 2, 0 to 1 or 2....he also has what you need obd2b to obd1! kenji211@tampabay.rr.com drop him a line! awsome guy to do business with, very good prices!
Old Mar 13, 2003 | 09:48 PM
turkdog's Avatar
hasport should have what your looking for too. Just talk to Joe. He has a lot of knowledge. He also does well with ecu's. 150 for a basic reprogram with v-tec
x-over and with rev limit or without. I would use an obd-I ecu like a P28 that way you dont have to add a wire for KS. You can use your OBD-II harness as well. It will clip right into your cabin harness which is on the shock tower on passenger side. There will only be 3 clips on the interior side and your OBD-II harness will have 4. Just dont plug in the 4th one. ITs the only one that doesnt match any of the 3 clips.
[Modified by turkdog, 6:48 AM 3/14/2003]
Old Mar 13, 2003 | 11:28 PM
B18C-EJ1
Guest
Posts: n/a
Why? Just use a USDM P30 or P28 chipped ecu and call it a day.
Old Mar 14, 2003 | 08:53 AM
rsaeini's Avatar
Default Re: OBD2b to OBD1 problem (B18C-EJ1)
That's exactly what I'm going to do. I'm going to be using a P30 ECU, I'm looking to buy one right now.
How would I know if it's USDM or JDM???
Old Mar 14, 2003 | 09:08 AM
turkdog's Avatar
If you look at your current ecu, note the size of it (regardless of which one it is) The P30-jdm will be much smaller is size (2/3) They refer to it as a small box.
Old Mar 14, 2003 | 09:12 AM
turkdog's Avatar
If you use your P28 you wouldnt need to add a KS wire. If you use a P30 you will have to add one. Do you know how to do that?
check out this website.
http://pgmfi.crx-forum.org/resources...D1USDM_JDM.jpg
http://pgmfi.crx-forum.org/resources...30USDM_JDM.jpg
[Modified by turkdog, 6:13 PM 3/14/2003]
[Modified by turkdog, 6:14 PM 3/14/2003]
[Modified by turkdog, 6:16 PM 3/14/2003]
Old Mar 14, 2003 | 10:34 AM
rsaeini's Avatar
Default Re: OBD2b to OBD1 problem (turkdog)
that helps a lot. now I know which P30 to get.
I don't know how to add the wire for the knock sensor. Does anyone have instructions for it. Pictures would definately help.
Old Mar 14, 2003 | 10:59 AM
eg6ajk's Avatar
if its 99 si swap complete with wiring hanress then simply plug it into your prexisting harness. this way you can just run the wires from the shock towers.
to add a wire simply use one of the pins which will not be necessary or hit a junkyard get a plug from any oBDI car and use those for adding VTEC/knock and so on.
mien_civic715
Jul 31, 2010 04:59 PM
lexrob
Feb 22, 2010 02:55 PM
vlc92189
10
Jan 29, 2010 10:50 AM
zenon8890
13
Sep 14, 2009 03:04 PM
soundman
10
Nov 14, 2003 07:59 PM
