Shimming the hybrid tranny
when getting the shim thickness of the main shaft,
Q1. How do you make sure that the bearing is all the way in the tranny casing?
Q2. When you are done measuring the shim you need, I'm not sure if you guys end up with the same problem as I have but the bearing tends to stay stuck in the casing. Is there a safe way of getting it out?
TIA
TIA
dazebreak
18
02-04-2013 06:06 AM
