B16 SWAP o2 sensor question
I have a 92 civic cx, i am putting a b16 in with chipped p28. My car has an existing 1 wire o2, do i need to change it to a 4 wire? If so how would i go about doing that. Also where does the o2 sensor need to be placed on the header.
Matt
Mraudio13@aol.com
Matt
Mraudio13@aol.com
Re: B16 SWAP o2 sensor question (mraudio13)
Yes, you will need to convert to a 4 wire O2 sensor using a P28, even chipped.
To do this:
WHT wire goes to D14 which is O2 Sensor Input (needs to be a shielded wire with ground)
BLK wire goes to A6 which is Heater Control
GRN wire goes to D22 which is Sensor Ground
BLK wire goes to B1 or A25 which is Sensor voltage
The O2 sensor is usually located by the the header collector, however there should be a tap on the header for you to place the O2 sensor in.
good luck.
To do this:
good luck.
Dancing is Forbidden
11-18-2003 08:51 PM
