Got to wire in vtec -- What gauge wires should I use?
I have the Cx motor out and the engine bay has been scrubbed down with a tooth brush.
This Tuesday my father and I will be installing the timing belt, water pump, distributor cap, rotor buttons, plug wires, plugs, valve cover gasket, and adding all the fluids.
I hope the same day to have the motor mounted in the bay as well.
Just wondering what gauge wires should I use for the vtec? I have the color for each wire. I can't remember if it's 18 or 20 gauge.
Thanks for any input on this!
Re: Got to wire in vtec -- What gauge wires should I use? (Hybrid93Hatch)
Do you not have any spare wiring from old harnesses laying around? I always salvage my wiring from other harnesses, then again I have a lot of harnesses to do that with
Re: Got to wire in vtec -- What gauge wires should I use? (VTECVillain)
Re: Got to wire in vtec -- What gauge wires should I use? (hatchdrvr)
No, I don't have any harnesses around. Got to pick the wiring up from an auto shop.
Re: Got to wire in vtec -- What gauge wires should I use? (PatrickGSR94)
Anyone know off hand what color wires are used from the factory for vtec? I would like to do the same if possible when wiring in vtec.
CAR: 93 Cx
MOTOR: 98 GSR
CAR: 93 Cx
MOTOR: 98 GSR
McBee
09-20-2010 06:03 AM
H22A EG6
06-14-2004 12:33 PM
