swap question
Old Mar 16, 2003 | 08:15 AM
JdmCIVIC853's Avatar
Default swap question
will the engine harness from a 91 civic hatch w/d15 work with a d16z6?
what all would one need to do this swap? the d16z6 does not have a wiring harness. thanks.
Old Mar 16, 2003 | 01:01 PM
Default Re: swap question (JdmCIVIC853)
lkadl;kfjasdkfj i need help
Old Mar 31, 2003 | 04:18 PM
okie dokie
Old Mar 31, 2003 | 06:25 PM
VTECVillain's Avatar
If you are installing the Z6 into the 91 hatch then you will need to use the stock harness because the Z6 engine harness will not plug into the chassis. You will need to change to MPFI and add additional wires for the VTEC solenoid and pressure switch. Then depending on the ECU or what method you decide to use to activate the VTEC, there will be some additional wiring.
gnccracer20
Feb 9, 2009 10:40 PM
Crimson_Tide
11
Jun 14, 2005 07:28 AM
sharky8513
Jan 22, 2005 02:44 PM
scratchy
Jul 31, 2004 05:57 AM
Tyreece04
May 10, 2004 04:38 PM
