CRVTEC injector size ?
Old Mar 16, 2003 | 07:58 PM
AVATAR's Avatar
Default CRVTEC injector size ?
Hey guys my motor was just installed the other day and I pulled two plugs out and they were pretty white. The car is running on stock 00Si injectors and stock ECU. Whats wrong and what do I need? Thanks
Old Mar 16, 2003 | 08:41 PM
tinkerbell's Avatar
Default Re: CRVTEC injector size ? (AVATAR)
you need to get a B&M ajustable FPR and set your fuel pressure to 50psi.
t..
Old Mar 16, 2003 | 08:51 PM
jdmcivicferio's Avatar
Default Re: CRVTEC injector size ? (tinkerbell)
get a colder spark plug, your proably running to hot
Old Mar 16, 2003 | 09:09 PM
tinkerbell's Avatar
Default Re: CRVTEC injector size ? (jdmcivicferio)
um, no - he is probably running too lean...
t..
Old Mar 16, 2003 | 09:51 PM
wHOAlly's Avatar
go 310's atleast, stock injectors max out at ~6k
Old Mar 17, 2003 | 06:24 AM
Jeff C's Avatar
Thats what I did and my air/fuels are in the green.
Old Mar 17, 2003 | 06:26 AM
Jeff C's Avatar
Default Re: CRVTEC injector size ? (There is no sp00n!)
How is that possible when stock redlines are 7k+?
Old Mar 17, 2003 | 06:57 AM
SiBirdie's Avatar
Default Re: CRVTEC injector size ? (Jeff C)
That's a False statement, Do you have any proof why stock injectors max out at 6k? Also I have talk to many crvtec builders and they all say it depend on your set up. If you are going to build a mild crvtec set up then stock injectors are fine and you just need an FPR. You only need aftermarket injectors if your set up is wild.
lates
Old Mar 17, 2003 | 12:16 PM
wHOAlly's Avatar
Default Re: CRVTEC injector size ? (SiBirdie)
lates
yes, on the dyno, i maxed em out at 100% duty cycle at ~6k on stock psi, and i have a very mild crvtec setup
Old Mar 17, 2003 | 12:22 PM
Jeff C's Avatar
on stock psi
I think that was your problem.
Old Mar 17, 2003 | 01:18 PM
tinkerbell's Avatar
LOL!
happy leaning
minimum FP for a crv block and vtec head on stock injectors = 50psi
http://www.rceng.com/technical.htm
t..
Old Mar 17, 2003 | 07:11 PM
wHOAlly's Avatar
LOL!
happy leaning
t..
exactly why im not at stock psi, im at 50, but even than, cant go much past 8k or so
Old Mar 25, 2003 | 01:53 PM
iH8BiTeRz's Avatar
Yup, 50 psi + 310cc injectors = your good to go
Old Mar 25, 2003 | 08:36 PM
Furry
Guest
Posts: n/a
Default Re: CRVTEC injector size ? (iH8BiTeRz)
on our stock b20vtec the stock 240cc injectors were hitting 90% out at 7400 rpms and going full open at 8000. monitored with the aem ems btw... we put in some obd2 prelude 290cc injectors and the max duty cycle they are seeing is 78% with 42 psi fuel pressure
killerpenguin21
Apr 27, 2007 03:17 PM
THMotorsports
May 2, 2005 02:33 PM
TypeR0207
Feb 10, 2005 03:42 AM
jonnybravo
Mar 18, 2002 02:23 PM
