JDM b20b == USDM b20z?
Old 03-10-2003, 05:59 AM
Will Albers's Avatar
Default JDM b20b == USDM b20z?
Does the jdm b20b have the same compression as a USDM b20z? are the fuel and ignition tables different for the USDM b20b/z and jdm b20b?
Old 03-10-2003, 07:05 AM
jeff652's Avatar
Default Re: JDM b20b == USDM b20z? (Will Albers)
CR is the same.
Dunno about the ECUs. Typically they are not imported with the longblocks.
HTH
Jeff
Old 03-10-2003, 07:11 AM
Default Re: JDM b20b == USDM b20z? (jeff652)
ooops,
Thank you much!
[Modified by Will Albers, 4:11 PM 3/10/2003]
[Modified by Will Albers, 4:12 PM 3/10/2003]
Old 03-10-2003, 11:40 AM
New User
Civic Rs's Avatar
two guys I know ad b20b JDM and the piston was the same than B20b USDM
Old 03-10-2003, 12:49 PM
Brrraaaap!
Blaze45's Avatar
Default Re: JDM b20b == USDM b20z? (Civic Rs)
got pics?
Old 03-10-2003, 01:00 PM
Cuong-nutz's Avatar
What you wrote gave me a headache! Well your friends are stupid for buying the same pistons. Probably because they don't know what they're buying.
96-98 B20B's in japan and US are pretty much the same.
99-00 JDM b20Bs are the same as the B20Z found in the use and come with a knock sensor and also that air chamber thing on top of the intake manifold.
edit: grammer
[Modified by Cuong-nutz, 4:01 PM 3/10/2003]
irev210's Avatar
Default Re: JDM b20b == USDM b20z? (Blaze45)
https://honda-tech.com/zerothread?id=407214
I had a good post about the differences
This will answer all of your questions
hope this helps
Old 03-10-2003, 01:09 PM
INVALID's Avatar
Location: Why so you can pretend like youre interested, FL/OK
Default Re: JDM b20b == USDM b20z? (Cuong-nutz)
Ah the link is listed above, but ah well.. here it is again as well with another one.
https://honda-tech.com/zerothread?id=394087&page=2
edit: grammer
Nice you made a edit for grammar then spelled the word incorrectly.
Nice to see you spitting out knowledge after recently receiving it, wasn't mine specifically, but ah well.
Old 03-10-2003, 01:44 PM
Cuong-nutz's Avatar
Default Re: JDM b20b == USDM b20z? (SHAUNTS99)
Haha! Your input was good but irev went into full detail But it's good to know that people are helping out each other.
porkchop
03-29-2004 08:52 PM
SleeprCrx
04-04-2003 06:09 PM
Will Albers
03-10-2003 08:18 AM
fire7882
02-28-2002 07:34 AM
jinxproof99
10-17-2001 03:24 PM
Quick Reply: JDM b20b == USDM b20z?
