gsr motor in 94 dx?
gsr motor in 94 dx?
in checking the 7 wires when i got to the secondary intake solenoid that goes into a17 it didn't look right so i checked my helms and it says a17 is for A/T lockup control solenoid should i still put it there
Re: gsr motor in 94 dx? (integra6650)
You're using an OBD1 P72 correct?
OBD2 is A20 for the IAB's, and OBD1 is A17. If you are using a GSR ecu then A17 is the correct.
Good luck
Good luck
Are you counting the pins as odd #'s on top and even #'s on the bottom? Or are you counting straight acros 1,2,3.... from left to right, top to bottom?
debogsr
05-12-2006 06:32 PM
NsX_CrX
11-18-2005 03:12 AM
