will a 00' gsr wire harness work in a b16 swap in a ek
Location: eastside of the beach, westside of the coast, Long Beach, CA, usa
i just got a 00' gsr wire harness and wondering if it will work in my swap, im doing a b16 swap in a ek4 or do i need a different year wire harness
Re: will a 00' gsr wire harness work in a b16 swap in a ek (dc2dragster)
From what I know EGs and 94+ tegs have two piece harnesses which plug into to each side of the shock towers. EKs use a one piece harness from the motor all the way to the ECU. I think ur best bet is to use an 96+ EX harness or SI harness.
If you have an ek4, use your stock harness. If you have a DX powered ek from 96-98, use your stock dx harness and add the plugs or get an ex harness. If it is 99-00, get the 99-00 si harness.
36Chitownrunnin
06-09-2008 09:28 AM
