b18c1 in 97 ls?
Old Mar 14, 2003 | 03:28 PM
dose's Avatar
Default b18c1 in 97 ls?
do i need to hook up any wires like vtec
Old Mar 14, 2003 | 07:30 PM
VTECVillain's Avatar
Default Re: b18c1 in 97 ls? (dose)
Yeah you need to hook up some wire like vtec and other stuff. LOL
Old Mar 15, 2003 | 05:56 AM
dose's Avatar
why cant i get a serious answer, what the hell is so funny about the question
Old Mar 15, 2003 | 03:46 PM
Well it's only common sense that since the B18C1 motor is a VTEC motor and the LS isn't, there will be some wiring involved. That being the VTEC wiring, Knock sensor and IAB. Maybe if you did a little research you would know that. If you want a serious answer, then ask a more serious question.
Old Mar 15, 2003 | 05:36 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
You may want to post this in the Integra forum, there will probably be more information regarding the swap in a LS there.
Old Mar 16, 2003 | 08:57 AM
dose's Avatar
i didnt kno i need to be so clear in my post i figured people could get the point, next time i will be more clear for those of you that are too simple,.i knew i needed wires to be hooked up but didnt kno which ones i dont kno much about integras i thought maybe the vtec wire is there already like on all 92 hatches its already there so i asked cause i thought i could get a straight answer w/o a bunch of sh*t
Old Mar 16, 2003 | 09:10 AM
Hybrid Invasion's Avatar
Ok, when you ask a question as vague as:
Then expect to get vague answers back. My reply would have simply been just 'yes' to something as nonspecific as the question you asked, but there were people nice enough to tell you that you might want to post in the integra forum to talk to people that have done the swap in order to help you. You'll get the answers you're lookng for, you just have to be specific on what you need to know, and search a little.
Old Mar 16, 2003 | 09:24 AM
THE GUY's Avatar
Not to be confused with "THE MAN"
Default Re: b18c1 in 97 ls? (Hybrid Invasion)
youll need to hook up v-tec solenoid(yellow/green),v-tec oil press(blue),v-tec ground(black),knock sensor(red/blue),evap purge power(yell/blackP),evap purge solenoid(red),secondary intakebutterflys(i forgot the colorbut the wire is easy to find. now the pin codes to where all those wires connect is dependant on the year ecu you use. a gsr will come with a p72 but i would reccomend a chipped p28 just from my past experience with them.any other info and you should either hunt it down or post in the integra board try http://www.theoldone.com they have lots of info but you need adobe reader to view the directions for some stuff
Old Mar 17, 2003 | 04:35 PM
dose's Avatar
where do i find the wires at the end of the engine harness near the battery?
ganjasnack
May 26, 2007 06:42 PM
92HB_HB
Jun 25, 2004 08:22 PM
