H22a Help
Old Mar 30, 2003 | 04:21 PM
junglerunna's Avatar
Default H22a Help
Alright I have 99 DX coupe with a 94 JDM H22a, im converting the car to OBD1 and I am using the DX engine wiring harness. Few questions
1. I have an 8 pin and 2 pin distributer sensors where does the 2 pin go?
2.There are 2 o2 sensors which one should I use and where should I put it?
3.Where should I tap into for the EGR, Vtec, and Knock sensor?
[Modified by junglerunna02, 9:00 PM 3/30/2003]
Old Mar 30, 2003 | 04:39 PM
poison's Avatar
Default Re: H22a Help (junglerunna02)
1 - Not too sure about on converting, like I told ya
2 - You'll want to use the front one on the header. The one on the Cat won't be used with OBD1
3 - As follows:
Exhaust Gas Recirculation:
Five wires need to be added.
EGR lift valve solenoid – sensor voltage (tap into Yel/Wht wire) & ECU signal to A11 pin-out
EGR lift sensor – sensor voltage (tap into Yel/Wht wire at the firewall), ground (tap into Grn/Wht wire at firewall) & ECU Signal to D12 pin-out.
VTEC:
3 wires total to be added:
VTEC Spool Solenoid goes to A4 pin-out.
VTEC Oil Pressure - Tap into D6 ecu pin-out and ground (Grn/Wht wire at the firewall)
HTH.
Old Mar 30, 2003 | 05:01 PM
bump for question #1
Old Mar 31, 2003 | 03:46 AM
Old Mar 31, 2003 | 05:26 AM
Jason kiDD's Avatar
Well you have to remember that your harness is ODB II as well so I would suggest getting an ODB I ex/si Harness to make your life easier if you want to convert to ODB I. That way most things will plug up and you wouldnt have to do much rewiring..
That is why you have two o2 bungs on the harness as well.
Old Mar 31, 2003 | 07:53 AM
fastwanabe's Avatar
Default Re: H22a Help (Jason kiDD)
look at your original engine and count the pins on its distributor plug then see if you can trace it back to its engine plug then compare it to the original location on the obdII plug.
Old Mar 31, 2003 | 08:27 AM
Default Re: H22a Help (fastwanabe)
Alright ill try that out thanks for all the help guys. Maybe in the beginning it would have been smarting to use an obd1 wiring harness, but now since everything is either extended or wired up its a little to late to switch wiring harnesses.
Old Mar 31, 2003 | 10:33 AM
Katman's Avatar
..you're best off going with an OBD2 H22 distributor, just so it plug n' plays w/your DX harness. Supposedly, you can repin your DX harness with OBD1 distributor plugs, just by matching up the distr. wire colors, but I can't back that up since I haven't tried it on my own.
Old Mar 31, 2003 | 01:07 PM
Default Re: H22a Help (Katman)
Alright thanks everybody, but on the P13 ecu how do I know which pin hole is what. For example if I am looking at the ecu which is A4 or D6 is there a diagram on some website that anybody knows of?
Old Mar 31, 2003 | 01:12 PM
poison's Avatar
Told ya before bro:
HTH
Old Mar 31, 2003 | 01:15 PM
Default Re: H22a Help (poison)
Thanks man, I never got those diagrams before, I guess we were misunderstanding each other.
Old Apr 1, 2003 | 04:51 PM
98HB's Avatar
I thouhgt I knew how to wire this but it seems every time I see a new post I get confused. I took a look at my EGR and these are the colors I have, also only 3 wires - (1)white/black (2)yellow/blue (3)green/black. Can you please tell me where exactly do they go. I have an OBDII motor converting to OBDI using conversion harness and a P13 ECU. -Please be as specific as you can-
Thanks,
98HB
3 - As follows:
VTEC:
HTH.
Old Apr 1, 2003 | 05:14 PM
yaya's Avatar
you are a GOD
LoudAccord
Jun 14, 2007 11:07 AM
sa210coupe
Nov 26, 2006 04:56 PM
type-t
Aug 19, 2004 06:39 PM
SuperNemeSis
Mar 29, 2003 02:32 PM
JMX
Nov 21, 2002 07:12 PM
