HELP!!! b18c1 into 98 civic ex, wiring harness help
quick tech question,
it's my first time swap, I just got a 98' usdm b18c1 w/ shift linkage/ motor/ tranny/axels/ ecu, (99 si braket on the way). but no wiring harness that goes to the ecu. will the wiring harness from my 98 civic ex(5-speed) work? and if it will, does it require serious know-how? or is it just plug and play? if any of you have performed this swap, please I could use any of you help to get by some of the struggle I may face. please I could use tips/tricks/ and know how...
thanks
thanks
Re: HELP!!! b18c1 into 98 civic ex, wiring harness help (98civicGSR)
Sounds like you are well on your way to the easiest way to swap the motor in.
Check the link in my sig.
spektrum
11-23-2002 04:15 PM
