D series Dist B series Motor
Hi im trying to swap a b16 in my DX hatchback and the dist is bad, can i use the D series dist from my stock motor on the b16? Thanks!
oh, both are OBDI
[Modified by hondanoob, 6:11 PM 3/28/2003]
oh, both are OBDI
Re: D series Dist B series Motor (VTECVillain)
I read somewhere that you can cut one of the flanges that bolts to the head off, and it will work....this is not a proven theory though...
Re: D series Dist B series Motor (Kamin)
LOL oh please i know of at least 20 things you can use from a d series motor on a b series
1. TPS
2. MAP
3. IAC
4. Injectors
5. FPR
6. Throttle Body (some)
7. PLug Wires (some)
8. IAT
9. Bolts
10. Hoses
You show me 10 more.
radiator, headlight bulbs, steering wheels, pedals, shift *****, 37hp Nopi stickers, fluid reservoir covers, battery, battery tie, and fuse box cover
haha
haha
the hoses dont work
diameter too small for b series lines.
well the radiator hoses dont.
[Modified by Kamin, 9:22 PM 3/28/2003]
Re: D series Dist B series Motor (Dark_Sol)
Those are chassis parts not B + D engine parts. Do not pass go, do not collect $200.
The dist guts are exactly the same. You can swap the guts out if you new what you where doing.
What is exaclty wrong with the b16 dist is the first place?
[Modified by TurboB16Coupe, 10:31 PM 3/29/2003]
blu3g
08-17-2005 04:00 AM
Lsssleeper Coupe
03-24-2005 02:15 PM
