chech engine light after swap
Old Apr 1, 2003 | 02:50 PM
NCchris's Avatar
Default chech engine light after swap
Put a 95 B18b into my 90 HF CRX. I used a 91 Teg dizzy, CRX injectors and a PR4 ECU. I am getting a code 1 and 3(O2 and map) I triple checked where I lengthened the map connection and it is good. I get the same codes with two ECU's. Both will crank and run the engine well. Just for ***** and giggles I hooked up the original ECU and it cranked OK and no codes! Any help or sugestions would be appreciated.
TIA
chris
ThatRicerDaniel
Aug 11, 2004 05:48 AM
Bongnak
Jan 10, 2004 06:34 PM
cliffjumpercrx
Jan 14, 2003 09:01 PM
89hb
Jan 13, 2003 01:05 PM
