how to increase rod stroke ratio on B20/vtec ??
i don't know much about these hybrid motors
i wanna build a B20/vtec
but im worried about r/s ratio
can I run a B18C crankshaft?
longer rods somehow?
Re: how to increase rod stroke ratio on B20/vtec ?? (Dan GSR)
If your worried then just go with a gsr block.It really depends on if you plan on resleeving the motor or not.Also check out the the tech forum,i think thats where this question needs to be.
I believe you can run a B17 crank in that but you'll have to run custom rods..
Do some research on that.. Probably cost too much to be worth it though..
The rod stroke ratio is not as bad as you think it is. There are plenty of people who have reliable LS/B20 VTEC setups, just make sure you get it built correctly and not by some lazy bum like me.
If you're worried about the rod/stroke ratio, just get a block girdle to keep the block more stable at high RPM. I hear block guards are worthless. Get your block balanced and blueprinted and all that fun stuff too.
Hope that helps.
Hope that helps.
75euRFE
10
08-24-2010 01:23 PM
