Are the 99-00 SI ECU pluggs same as the 99-01 GSR and what wires have to be changed to make it work?
Well smogg day is in the near future and I need a ECU to run for the crappy SMOGG guys. Thing is if im not sent to the ref im going to do it under the table probably. BUt if I am sent I need to find a ECU to run. I swapped a 01 ITR motor in my car and the SI Ecu runs to lean so I know it wont pass etc so I was thinking of getting a GSR CPU for the car just for the test but I need to know if it will be just plug and play with a 99-01 GSR CPU. I know the 00-01 ITR ECU is plug and play but damn imobi gets in the way errrrrrrrr and if I take it out it will throw a cell witch I cant have. ALSO do the GSR ECU's have the damn Imobi? Any help would be great thanks.
chris
chris
Re: Are the 99-00 SI ECU pluggs same as the 99-01 GSR and what wires have to be changed to make it w
99+ GSR ecu have immobilizer.
I would try to pass with an SI ecu.
The 00-01 Integra plugs are the same as 99-00 Civic's. But as stated, they have an immobilizer built in so there goes that idea.
errrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr SOB damn thieves cause of them they made the imobi errrrrrrrrrrrrr or else this would be so easy *&#%(*&$#*$#$
Send the ECU to Katman....he can remove the immobilizer for $55 dollars I belive.
