Eg / GSR Hybrid! Someone post a checklist of what needs to be wired up / connected!
Just would like a list of all the hoses / wires that need to be connected.
--Throttle cable
--Battery power wires
--Radiator hoses
--Valve cover ground
--Shift linkage
--Axles
--vtec wiring: https://honda-tech.com/zerothread?id=306097
https://honda-tech.com/zerothread?id=306096
https://honda-tech.com/zerothread?id=291314
https://honda-tech.com/zerothread?id=293366
https://honda-tech.com/zerothread?id=292635
https://honda-tech.com/zerothread?id=324527
http://www.civichatchback.com/board/...&threadid=6116
Please feel free to add to the list. I'm about to go outside and start on some of the connections. Just would like a guide to make sure I get everything
--Throttle cable
--Radiator hoses
--Shift linkage
--Axles
Re: Eg / GSR Hybrid! Someone post a checklist of what needs to be wired up / connected! (Hybrid93Hat
ECU Wiring:
VTEC Solenoid
VTEC Pressure Switch
Intake Air Bypass (IAB)
Knock Sensor
O2 Sensor - Convert to 4 Wire if needed
Hoses:
Upper Radiator
Lower Radiator
Heater Core In
Heater Core Out
FPR
Brake Vacuum
TB Vacuum
Charcoal Canister Vacuum
Probably more in each category, just can't think of anymore at the moment.
VTEC Solenoid
Knock Sensor
Hoses:
Upper Radiator
Lower Radiator
Heater Core In
Heater Core Out
FPR
Brake Vacuum
TB Vacuum
O2 Sensor - Convert to 4 Wire if needed How would I know if I am converting to 4 wire or not?
Thanks man!
Here are some pics I took of the connections with some text.....
Where does this 4th GSR engine harness go? (Passenger side)
Any idea what hose goes to #1? Where does #2 connect to the motor?
I'm going to just use the Cx charcoal canister. Where do each of the numbered hoses go to on the GSR?
It's a little different than the GSR's canister:
Here''s how the GSR is connected to the motor:
#2 is wired to the motor / canister
#1 is wired to the canister, but capped off where it connects at the motor
Pic says it all here:
What's the purpose of this gold thing on top of the passenger GSR mount?
VTEC wires coming through the firewall. Just 4 right?
Is this the headlight wire harness? I can't remember at the moment what was connected to it:
93CX - 98GSR
Thanks again for all the help!
Thanks man!
93CX - 98GSR
You have a 93 CX which has a 1 wire O2 Sensor. You'll need to convert the wiring to a 4 wire O2.
That's the Intake Air Bypass which mounts under the intake manifold
Thanks once again!
I never looked at the pic close enough. Just use your ctock CX canister. The hoses will connect to it but there will be one outlet that will not have a connection. I plugged mine off with a screw. There won't be any wiring only the vaccum hoses.
Where do 2 and 3 go?
connect 2 to a vacuum source
Where at?
Where at?
connect the larger one(#3 on cx canister) to where #2 on the gsr canister connects to(top of manifold)...so if one is plugged i guess it is the small hose on the cx canister?
#2 in this picture should go to a vacuum source
and #3 in this picutre
needs to go to #2 in this picture
Let me know if you got it this time or not.
i get all of it but i dont know where the vacum source for #2 is
from any vacuum nipple. it doesn't matter. if yu have to get a vacuum t
Sorry for all the Q's! This is all new to me
If you see a hose about that size coming off of the intake manifold or if that hose on a port on the intake manifold put it on there. a vacuum t looks like a t and lets you run more than one hose form the same source. u can find it @ any auto parts store. Just make sure it is the right size.
there is a vacuum nipple on the back of the intake manifold near the driver side you can t into there. just make sure you connect the one that is there back cause it is for your secondary and fuel pressure regulator i believe.
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
if you need any more help, call me at 927-1768 (kevin). lookin out in the 'sav'.
If the weather is nice tomm. I will be installing the shift linkage, axles, new rotors, and radiator.
Ok my friend got a complete gsr swap and his swap didnt come with that canister he is holding in his hand. Is this required to make the second butterflies work right? Since the IAB is on that canister right. So does this mean he needs to go buy this canister? Or is this already on the car? This motor is going into a 92 integra. If so thats wierd cuz ive never heard of this canister coming with the swap. Or is there another IAB that I can use to wire to the ecu for the second butterflies? thanks
That canister I am holding is the charcoal canister. It's something to do with emissions I believe. I have read in a few threads where some people don't even use one. I am just going to use the Civic's and leave the GSR's off.
And also since this is going into a 92 integra do I need to still hook up the o2 sensor? Do I have to convert it to a 4 plug wire like stated above. thanks
