b20z compression ????
Old Apr 1, 2003 | 10:08 PM
othick's Avatar
Default b20z compression ????
I've read that the b20z found in the newer crv's has higher compression than the b20b's found in the old ones. Is this true? Would all b20z's have higher compression than b20b's? Would the compression ration change with a b16 head on a b20z block?
Old Apr 2, 2003 | 01:04 AM
irev210's Avatar
Default Re: b20z compression ???? (othick)
https://honda-tech.com/zerothread?id=460954
That will explain everything for you.
Old Apr 2, 2003 | 10:31 AM
othick's Avatar
Default Re: b20z compression ???? (irev210)
That is perfect, thank you very much. Does anyone know if the compression would still be 9.6:1 with a b16 head on it?
Old Apr 2, 2003 | 11:21 AM
Newman's Avatar
New User
With the stock block, it's around the same.... 9.8:1 or so, nothing drastic until you change pistons.
Old Apr 2, 2003 | 11:43 AM
irev210's Avatar
Default Re: b20z compression ???? (Newman)
yah around there, 10:1 to be exact, a b16 head will raise the compression by .4
a GSR head will raise the compression by .6
Old Apr 2, 2003 | 04:32 PM
Jeff C's Avatar
So if I have a b20 block with 10.5 JE's and a 1g b16 head, then my compression should be around 10.9:1?
KillaB18
Apr 2, 2005 07:58 AM
The Destroyer
Oct 6, 2004 07:51 PM
Thrashin
Aug 10, 2004 02:41 PM
