Type R Fuel Pressure
I am setting the fuel pressure on my 97 jdm R swap right now. It seems like i cant get it set right by the feel of the car. I have it set around 45-48 right now i believe and it seems to be running fine. What should my fuel pressure be set at? Also everytime i hit the gas at night with my headlights off they dim but it i let off of the gas pedal for about 3 seconds the headlights look normal again. The gauge cluster is doing the same in sync with the headlights. Any ideas? thanks
Re: Type R Fuel Pressure (ZigenGSR)
i thought 48-50 psi with the vacuum hose removed was stock Type R?
teh headlight problem could be anything, more description needed...
t..
t..
Re: Type R Fuel Pressure (tinkerbell)
i dont really know how to give more details about the headlights. Its like an electrical problem somewhere i guess. just wondering if anyone had any idea of what it could possibly be.
The fuel pressure should be from 48-50 on stock internals and stock pump.
As for the dimming headlights/gauge cluster, that sounds like an issue with the alternator charging the battery...
Either the alternator is probably not charging the battery 100% or the battery is low on water inside, or the battery is bad.
RyanA
52
01-13-2018 04:48 PM
