Wiring up Vtec for swap
Does any one have step by step instructions on how to wire up the vtec for a 99 type r motor in a 94 DX hatch? Pictures would help also. I am going to attempt to do this myself but I dont wanna mess things up. Thanks guys and girls.
Re: Wiring up Vtec for swap (SuperNemeSis)
Wiring VTEC is very simple. It's three wires.
All you need to do is follow the VTEC Pressure sensor and the VTEC solenoid to the ECU.
You may wire VTEC by doing the following:
Follow from the VTEC Spool Solenloid to A4 pin-out at the ECU.
VTEC Pressure sensor goes to ground (tap into Grn/Wht wire at the firewall) and D6 pin-out at the ECU.
HTH.
HTH.
Re: Wiring up Vtec for swap (poison)
Ok so you have wire three wires but the vtec pressure sensor has to be ran to the ecu and grounded? How is this done? does it have one wire for you to run to the ecu and another that you use for a ground?
Re: Wiring up Vtec for swap (Project92Hatch)
Re: Wiring up Vtec for swap (RuffRhyno)
yes, you can ground it on the motor or on bare metal, or you may use an ECU ground or tap into the Grn/Wht wire.
ilovemyb16a
05-18-2006 12:58 PM
