add ckf to obd1 engine?
Old Mar 30, 2003 | 03:53 PM
v4lu3s's Avatar
RTFM
Default add ckf to obd1 engine?
hey im working on a b18c1 swap in a civic hx (96 or 97), i ahve an obd2 b18c1, obd2 harness that was modificed by a monkey (im fixing it right now) and an ob2 p72....now several things i saw NOT hooked up when the swap arrived were the CKF sensor, and an evap purge solenoid.
is there a way to put the CKF on the b18c1? or can i safely ignore it without codes?
if possible i want to keep this engine obd2 for emissions reasons...
Old Mar 30, 2003 | 10:21 PM
Trickturn's Avatar
Default Re: add ckf to obd1 engine? (v4lu3s)
If it is not there... add it.
Pete
Old Apr 1, 2003 | 10:43 AM
v4lu3s's Avatar
RTFM
found out i would need a new oil pump to add the sensor
and that an obd2 p72 will not throw a code for it if it is missing....nor will it throw a code for the second o2 sensor that isnt htere.
90Rexx
15
Feb 6, 2010 09:20 PM
joeitovtec69
Sep 25, 2009 05:15 AM
Brugalontherocks
Apr 28, 2008 08:10 PM
FrederickRighteous
Mar 17, 2008 11:27 AM
2004es2
Feb 28, 2008 01:45 AM
