b18b in an EG lower rad hose
Re: b18b in an EG lower rad hose (girlyEG)
You can use your stock single cam hose or upgrade to a 99-00 si larger diameter hose. Actually I think the bottom hose connects at the same spot on most all civics and tegs 88-up so any should work. I bought a 99-00 lower hose but used the stock one sine it was fine, just had to work it onto the b-series thermostat housing.
xotic_crx
10
10-01-2013 04:08 PM
