96-00 Civic/GSR swap
Re: 96-00 Civic/GSR swap (snoballgsr)
purchase a full gsr swap including axles, shift linkage, tranny, ecu (p72), motor and engine harness...
yes it's direct bolt in.
what do you need?
to click on the search button.
what do you need?
1 Post
Its pretty straight forward. Very little actually has to be done. Check out my swap at http://repo.jackmoves.com/view...bun03
Re: 96-00 Civic/GSR swap (monicle)
i keep hearing and seeing 00 si motor mounts being used. i have a complete gsr and civic ex. a shop will be putting the gsr motor into the civic. i asked if the needed anything else and the said no that the gsr has everthing they needed, it that true. also the 96+ civics are obd2. i heard that the 94-96 integs have obd1. would you shine some light on this subject thanks. sorry to steal your post bro
Re: 96-00 Civic/GSR swap (bgx9ner)
yes you want to use si engine mounts...94-95 gsrs are obdi...you can use an ecu jumper and run the obdi ecu...if not you'll end up getting a cfk code and i wanna say a o2 sensor code if running an obdi motor in your 96-00 civic.
Good luck
Good luck
Re: 96-00 Civic/GSR swap (whitelightning)
good my civic is a 96 and the gsr is a 97 so i should be ok and there will be no need for an ecu jumper right? i'm going to check for how much the mounts cost but whats a good price?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bgx9ner »</TD></TR><TR><TD CLASS="quote">good my civic is a 96 and the gsr is a 97 so i should be ok and there will be no need for an ecu jumper right? i'm going to check for how much the mounts cost but whats a good price?
Which ECU do you plan on using and what year is the motor you are getting?
TurboBumblBee
14
01-15-2002 10:32 PM
