JDM b18c into a 1998 Integra LS (PLEASE HELP!!!)
OK, here's the story:
I bought a OBD1 JDM b18C that has a OBD2 distributor and an OBD2 JDM P72 ecu. I installed this motor into my 1998 Integra LS this weekend.
The motor turns over but will not start.
I have double checked all the plugs, they're all plugged into their respective sensors except for the CFS (crank fluxuation sensor, supposed the JDM ecu won't look for this and there isn't one on the motor)
The grounds are all hooked up
The injectors are firing (plugs are wet when i pull them)
I replaced the plugs and wires
I replaced the distributor with a known good one
48psi of fuel pressure at the filter
The plug wires are getting spark, though it seems irratic
None of the VTEC specific wires are hooked up to the ecu yet (they shouldn't need to be to get the car started right?)
Why won't this ******* car start!?!??
ARGH!!
Myself!
ARGH!!
Myself!
93bubble87
05-20-2010 07:52 AM
