b18c1 swap into 2nd gen Integra
trying to help a freind out.
hes got a gsr"b18c1"
Skunk2 IM
2000 Si Pistons "PR3"
ITR Camshafts
DC 4/2/1 header
Port/polish
adjus gears.
it will be dropped in a 90 gs.
As he is non obd and with all this work done and the head shaved a bit.. hes atleast in the 11:8 compression.
Will the stock b18a injectors work or will he need to upgrade.
Also he will be running stock pr3 . is that sufficient? i'm worried he will be running lean.
Some say he needs his ecu chipped and some say he needs a FPR.
Please advise.
Skunk2 IM
ITR Camshafts
DC 4/2/1 header
Port/polish
adjus gears.
Please advise.
Re: b18c1 swap into 2nd gen Integra (GsTeg90)
Re: b18c1 swap into 2nd gen Integra (VTECVillain)
When u say he needs stock resistor box, do you mean use evrything from his b18a harness along with stock injectors.
Also u mentioned he can stay with stock pr3. pr3 being a 1.6l ecu and he is now a 1.8l with 11:8 compression, u think all he will need is FPR?
i just dont want this guy's engine to blow. trying to be a good freind.
Help is appreciated.
GsTeg90
GsTeg90
excelelnt , so its safe so say.. keep stock pr3 and use stock b18a injectors and engine will run without anything lean issue to worry about.
vtec25
12
04-17-2006 05:40 AM
