Which throttle cable to use: GSR or EG's? Eg / GSR Hybrid! Pic of both inside!
The motor is mounted in the Eg
The throttle cable is still on the 98 GSR and the throttle cable for the 93 Cx was just disconnected from the engine.
Does it matter which one I use?
GSR cable -- mounted to engine
CX cable -- coming from firewall
You are looking at opposite ends of each. The end you see for the Cx is the other side of the GSR (mounted to the engine). The end you see for the GSR is the Cx's part that is connected under the dash or whereever it goes.
Are they the exact same? It will probably be easier to hook the Cx up at the throttle than to run the GSR into the firewall. But, if the GSR's must be used, GSR it will be
Re: Which throttle cable to use: GSR or EG's? Eg / GSR Hybrid! Pic of both inside! (Hybrid93Hatch)
You can get the CX one to work using the bracket on the intake manifold. But the GSR would be cleaner and more for the job and fit properly.
HT's Biggest Loser
Re: Which throttle cable to use: GSR or EG's? Eg / GSR Hybrid! Pic of both inside! (poison)
i have used stock cables in many swaps, but thats only because i didnt have a cable handy. Since you already have the gsr cable, mind as well hook it up, its not that hard to remove the cx one and install the gsr one, good luck.. Ron
Re: Which throttle cable to use: GSR or EG's? Eg / GSR Hybrid! Pic of both inside! (SIXTYdashONE)
I'm glad someone asked this. My swap just arrived with the cable cut, so it's DX throttle cable for me!
Re: Which throttle cable to use: GSR or EG's? Eg / GSR Hybrid! Pic of both inside! (saber1)
Would anyone off hand happen to know how difficult it is to remove the Cx and put the GSR in? ....I'll check my Helms in the meantime
Re: Which throttle cable to use: GSR or EG's? Eg / GSR Hybrid! Pic of both inside! (DA6-XSi)
I looked through the Helms today to see exactly what was all done. I was bored art work. Anyhow, couldn't find it after about 30 minutes of looking through the book. I feel confident with the 2 statements above
Took about one minute to pop the Cx cable out and install the GSR cable
eggsi619
06-29-2009 11:14 AM
HXMan
05-08-2003 08:20 PM
