H23 into teg using LS ecu / what style injectors?
If you put a H23 into an integra using the integra wire harness and ECU, do you use the integra saturated injectors or the prelude peak and hold injectors?
As I understand these are not compatible with each other.
Re: H23 into teg using LS ecu / what style injectors? (Westrock2000)
Re: H23 into teg using LS ecu / what style injectors? (VTECVillain)
You would use the injectors that match the ECU, in your case any 92-01 Integra injectors will work. Just match the OBDI/OBDII so you don't have to splice different injector clips.[/QUOTE]
ive tryed using the ls ecu for the h23 and the car dies unless you keep your foot o the gas pedal. i have an h23 ecu for sale for 50 bucks.
the integra injectors are only 250 cc or something and the h23 re 320cc. y would you wanna use the interga injectors.
use h23 ecu and injectors. trust me h23 wont run right with a p75 unless you chipp it. i got an ecu so im me if you want it.
HEY VILLIAN help me out im putting a 98 type r in to a 92 VX i know you know yo sheet so im me and help me out
