will not rev past 3k b16 swap
i just finished putting a first gen b16 into my 89 crx dx... did all the mpfi stuff.. now she will not rev past 3k... it back fires really loud too at 3 grand... anyone got any ideas...
please thanks
please thanks
Re: will not rev past 3k b16 swap
check ur timimg make sure they are correct .... if u dont know how to check the timing..there s another way to check it out .,.. start the engine and reving to 3k rpm then turn the engine off without let the rpm going down then pull out the spark plug and see what the color it is... if it s blackish then u have the wrong timing
better to fixing it before it ruin ur beautiful motor~! ! ! ! this just remind me like my mimi-me i try to fix it eveything but havent check the timing..
good luck
good luck
Re: will not rev past 3k b16 swap (dutchman5)
i had the same problem with a P28 and a C1 swap. it would fuel cut at 3500. turns out to be a messed up ECU. swapped with a known good ECU and problem solved.
wdbdycrx
03-16-2005 06:41 PM
dropd4door
10
04-02-2003 07:30 AM
