92-93 B17A Dist. OBD1??
Old Mar 31, 2003 | 06:02 PM
sweet's Avatar
Default 92-93 B17A Dist. OBD1??
i'm not sure if the 92-93 B17A distributor is an OBD or OBD1?
i would think OBD1 since the Civic's starting in 92 were OBD1, but i just wanna be sure. the reason i'm asking is i need an OBD1 DOHC VTEC dist. and was wondering if a B17A dist. would work without any modification or at all.
thanks for any feedback.
Old Mar 31, 2003 | 06:05 PM
poison's Avatar
Default Re: 92-93 B17A Dist. OBD1?? (sweet)
yes, the b17a is obd1 with a p61 ecu.
it should clip right in.
Old Mar 31, 2003 | 06:07 PM
sweet's Avatar
Default Re: 92-93 B17A Dist. OBD1?? (poison)
thanks poison, i appreciate the quick response!
Old Mar 31, 2003 | 06:09 PM
poison's Avatar
np
VTECVillain's Avatar
Correctomundo
Old Mar 31, 2003 | 08:21 PM
DA6GSR's Avatar
Default Re: 92-93 B17A Dist. OBD1?? (VTECVillain)
It all depends on what color connectors you have. If you have a gray connectors then it is ODB1. If it has black connectors then it is ODB0.
Old Apr 1, 2003 | 04:55 AM
Default Re: 92-93 B17A Dist. OBD1?? (SloSpeedRacrGSR)
The 92-93 B17A (GSR) are ALL OBDI. Only the 90-91 Intega's were OBD0.
HondaRexBoi
Apr 20, 2021 11:52 PM
ricardo13d
11
Dec 8, 2011 06:55 PM
91dxcrx
Jan 22, 2006 05:46 PM
ShoeGuy#1
Apr 1, 2003 08:35 AM
