wiring harness pins
wiring harness pins where did you get yours?
I have an EK hatch that I just recently got a 99 GSR motor for.
The question I have is where did you guys get the pins for the
wiring harness to run the Vtec wires? I didn't get the harness
part that plugs to the ecu with the GSR motor so I don't have
any donor pins. Did you get them from Honda, or get a scrap
yard harness, or can you just solder them in?
We are going to try to finish the swap this coming sat. and
I want to make sure I have everything I need. Thanx for any help
How do the wires go into the clips that plug into the ecu?
Whats up with the archived search engine?
[Modified by nyEKhatch, 9:53 PM 3/29/2003]
[Modified by nyEKhatch, 10:05 PM 3/29/2003]
