jdm B18c in EF IAB/knock/02 sensor query
Hey guys, So I have a converted to 0bd1 EF running a P28, standard jumper harness to plug my obd0 plugs into.
I've been reading up on wiring up VTEC, and the IAB butterfly valves.
I am frankly confused at this point.
To my knowledge the P28 was burned with a map that doesn't utilize and 02 sensor.
Secondly, from reading, 0bd1 P28's don't run a knock sensor? (Please confirm this for me)
With those two variables essentially out of the mix, as per this pic:
Do I simply ignore the 02 and knock pinouts altogether and simply add a wire to A17? This wire on A17 supposedly runs back to the IAB valve plug, and on my car there are two wires.. red/white, and green/white.. I am not sure which of these the A17 should splice to?
Lastly, as per VTEC, with the above information I only have to pin into jumper wires on A4 and D6? (If there are wires already in those pins I assume I would just splice into these existing wires?)
Sorry for the long winded post.. Just trying to sort through this confusion.
Technical Hero
Re: jdm B18c in EF IAB/knock/02 sensor query
Here's the wiring for VTEC, ignore knock and Iab as the p28 doesn't use it, also if the ecu chipped out the 02 I guess you can ignore it too
Thanks! the B18c will run properly without the IAB engaging? I also believe I have the EVAP canister as well to wire up.
Just want to make sure before I dig in and make anymore mistakes.
Technical Hero
You can run the evap if you want but it won't throw a code. With the IABs most people run a skunk 2 type manifold and eliminate them altogether. Otherwise they stay open all the time and you'll lose some low end torque.
BlackCivicEX
01-25-2011 11:54 AM
beginmyhonda
07-29-2009 02:14 PM
