h2b question
I got 94 integra and ultimate goal is all motor running low 12s high 11s. I been told a h motor is the way to go to achieve my goal of 220-260whp.
I'm however not sure which motor to get or if I should use my ls trans to achieve my goal.
The reason for the build is that the current b18 is taken a dump on me due to rings.
HMOmotorsonline.com is the way to go if your shopping for a swap. I believe the H22a comes with a bit more HP stock compared to the usdm H22a4. Popular transmissions with an H2b setup is a Type R trans or more common a B16 trans.
An H2b setup isnt cheap by any means at all....My stock H build has totaled about 3gs so far. Bisimoto makes a good H2b kit, check them out forsures
Being that you have a integra already you already have the trans mounts axles shifter and linkage you will need whats left to get is a engine and h2b kit I would look into getting the qsd kit its 700 new and as far as engine the best bang for the buck would be the h23a vtec blue top fir around 800 depending on who you get it from
REHTE_DC2
Jul 14, 2011 06:23 AM
