B18c swap no spark
B18c swap no spark
Hi guys just finished my b18c type r swap and I got no spark, I have fuel pressure, I wired up the crank sensor bypass and also the vtec oil pressure switch bypass, I'm using ex civic harness and odb2b p2p ecu my car is 99ek
The engine turns over fine but I checked the splug wires to see it it sparks and nothing,
Pls help
Pls help
Re: B18c swap no spark
My distributor is plug and and play
My vtec fluid I'd good
Ill disassemble my distributor tommarow to check the igniter
Just wondering if there is another bypass I have to do
Jeremy Harris
21
05-02-2016 10:58 AM
ej8fosho
10-30-2008 09:29 PM
