LSVTEC with RC injectors..HELP!
Old Sep 1, 2013 | 02:07 PM
Nick_Cartwright's Avatar
Icon6 LSVTEC with RC injectors..HELP!
PLEASE BEFORE ANYONE COMES BACK WITH COMMENTS SAYING I JUST NEED TO DO MY OWN RESEARCH I DEFINITELY HAVE TRIED TO SEARCH BUT MY SITUATION IS JUST SO DESCRIPTIVE I AM HOPING TO GET HELP WITH SOMEONE WHO MAY HAVE HAD SAME EXPERIENCES.
So I have a 2000 civic SI with a fresh built lsvtec. Motor is as follows:
B18b1 Block with type R pistons
Fresh rebuilt B16 head with type r cams
Skunk2 intake mani with 4-2-1 headers dc sports full 2.5 in exhaust
The problem I have is I bought a set of RC injectors and got them installed as well as a chipped p28 with basemap chip for build..they were running fine at first then all of a sudden car started missing really bad (so after daignosing almost everything) I put factory injectors back in with factory ECU and car went back to running like it did before (which is not great because of factory injectors and ecu doesnt like displacement from 1.8 bottom end)
So when I figured this out I decided to take them to local shop to be pressure tested and cleaned because I bought them used so thought they may be clogged ....Got them back installed back into car and car was running good for about 200 miles then suddenly back to square one...started missing AGAIN!! So again I put factory injector back in and went back to normal once again.
After this I thought to myself that maybe the electrical to injector was bad so I cont'd to diagnose. I put them back on and unplugged each injector while car was running one by one and noticed one of them didn't make it bog down like other 3. I got my multimeter and checked resistance in this one injector and it read 14.0 which is what it should be.
SO HERE IS MY QUESTION COULD THIS ONE INJECTOR BE BAD EVEN THOUGH THE PRESSURE TEST AND MULTIMETER SAY OTHERWISE?? I AM BEGINNING TO GET REALLY IRRITATED WITH IT. DID I JUST MAYBE GET SOLD A BAD SET OF RCS? ANY HELP AND/OR INPUT WOULD BE GREATLY APPRECIATED.
Old Sep 1, 2013 | 02:20 PM
grumblemarc's Avatar
The Grumpiest
Default Re: LSVTEC with RC injectors..HELP!
Why are you running RC injectors? Which RC injectors? Why is this not tuned?
Old Sep 1, 2013 | 02:28 PM
instrument's Avatar
yeah, nothing about your build requires injectors unless I missed something
Old Sep 1, 2013 | 02:29 PM
Factory injectors will be running 100% duty cycle at 7200rpms and im sorry I meant to say I have a chip burned and tuned for the build as well as for theRC injectors.
Old Sep 1, 2013 | 02:33 PM
The Grumpiest
100% duty? How do you figure that? I don't see anything that would push factory injectors that hard. And still doesn't say What injectors he is running. A basemap is not a tune.
Old Sep 14, 2013 | 08:08 PM
the171's Avatar
RCs... I never had this problem but I do believe there are better choices. I ran RC 440s for a couple years. Car ran OK but was very sloppy at lower rpm. There are definitely more advanced choices nowadays.
Im now in the middle of switching over to Denso (RDX) 410cc. Im hoping for much more crisp throttle response, low RPM operation, better fuel mileage, and tighter closed loop. We'll see how much difference it makes.
epic.fail
Mar 3, 2012 12:35 PM
cnydc2
May 26, 2005 04:41 PM
Rod.
Apr 5, 2004 06:22 PM
EFGeeSeR
Nov 3, 2003 03:16 PM
Dragger817
May 28, 2003 09:20 PM
