eg ls swap gsr trans
Background info
Ls is from a totaled integra I took the half shaft and axle from the driver side (side that was hit) because someone else had taken the other one
So I have everything swapped got it to start but I have an issue . Its running but whenever I let go of the clutch it slowly drops rpms from about 2k down to 1k and I hear a grind . I tried to move it and it won't move just grinds even when the cars off. I tried to start it and drive it and once again when I let go of the cultch to get it going it grinds . Any ideas what I could be? Bad clutch alignment? Bad axle? Bad tranny?
ceearexx
02-27-2013 12:35 AM
