b18b1 swap in a 93 del sol si.......what should I look out for???
just what it says. the engine in my del sol is out and I've decided to do an ls swap. what all do I need from the ls? engine tranny mounts ecu wiring harness cv axles and what should I look out for?
Re: b18b1 swap in a 93 del sol si.......what should I look out for???
basically everything
you need a DEL SOL VTEC shift linkage the LS linkage is too short for del sol chassis
I did this not so long ago. The mounts are the same, you need a dc rear t bracket, your stock harness should work with the motor, DC axles, one of the most important thing on that swap is you need to have del sol vtec shift linkage.
roque-pr
19
03-24-2010 05:21 PM
mikej94civex
02-07-2010 05:40 PM
spike
07-30-2004 10:45 AM
